Dear support I need help with post text formating.When I create post it looks like : see picture below. I need to have text inside the borders
Page is not live yet.working on local host. also posts are not appearing at home page where should i see my last posts. what another info u need?
Hello, Theme don't have such problem. There maybe two possibilities for this issue. 1) Any type of customization done at your end. If yes then download theme again from your members area and upload it. It will resolve this issue. 2) Any installed plugin is causing this issue. So deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). Thanks & Regards Nitesh Raghuwanshi
