Postal Code.. need to change.
Discussion in 'ClassiCraft WordPress Theme' started by gjspinney, Mar 12, 2017.
  1. gjspinney
    gjspinney New Member
    Canada Eh!
    In the search bar Postal Code shows up when you first visit the website..
    I changed the classicraft.po language file to Zip Code, but can't find what else needs to be changes.
    Please can you guide me in the right direction to solve this problem.
  2. gjspinney
    Canada Eh!
    Never mind digging though all our support emails, look like I found the solution.. (Hope this thread helps others)
    To change the text "zip code, city, address" to your desired text, just follow the attached screenshot.
  3. Naveen
    That sounds great :)
