On the Posts Page how do I remove the following text: 1) Posted by Peter Posted in Uncategorized Oct, 20, 2014 No Comments. as well as the open and closing lines surrounding that section of text. 2)← Previous Post Next Post → - to remove 3) Leave a Reply - To translate and edit to "Faka Umbono" 4) Logged in as Peter. Log out? - To not show / to remove 5) Comment - To Edit text to "Umbono" 6) Post Comment Button - to edit button text to "Thumela"
Hello, 1 ) and 2) Paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .content-bar .post .post_meta{ display:none; } #nav-single { display: none; } 4)Logged in as Peter. Log out? This show because You are admin and you are login. User cannot see it. You can remove- Paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: p.logged-in-as { display: none; } 3) & 5) & 6) For translation use any plugins because these cannot be manually changed these comes from wordpress files. Thanks & Regards Pramod
