POSTS
Discussion in 'Infoway WordPress Theme' started by bizgirl, Mar 20, 2017.
  1. bizgirl
    bizgirl Member
    Hi there
    It would be greatly appreciated if you could tell me how to change title on the green button for my posts in the image below. I would like to change the current text which says Take a Tour.
    Temporary website is http://promotion.ctpaustralia.com/
    Many thanks as always
    Maggie
  2. nitin
    nitin Guest
    To edit the text 'Take a Tour', you need to make some changes in the source code of the theme.
    To do it, just go to define_template.php file under infowaytheme\functions\define_template.php. Then on line number 45 you will find this text, just edit it to make it as per your requirement.
    You can use the "WP-Editor" plugin to edit source files. You can download the plugin from the link https://wordpress.org/plugins/wp-editor/.
    Hope this helps...!
    Nitin
