Hi, could anyone please advise if there is another plugin instead of wp copy-protect that will work with this theme, I think somewhere this plugin was mentioned on threads. I have been trying it and it works ok giving a notice no right click, but when I click ok to close message box, a box opens to allow source, which defeats the plugin use. The support for the plugin mention that the theme must have <?php wp_footer(); ?> just before the ‘< /body >‘ tag in footer.php but on checking the Geo theme already has this code in footer. Anyone else experiencing this or know of other plugin I would appreciate info. Thank you all, Tob
Try this one - I use it on many of my sites including my Geocraft ones with no problems. "No Right Click Images Plugin" by Keith P Graham Roger
Thank you Roger, that could be more what I am looking as trying to protect the content plus avoid access to the source files to make it difficult for business to check what theme I am using and starting up in competition WP Copy Protect has done this in previous sites but with this great theme I am getting the message box showing view source after closing no right click box. Many thanks Tob
Anyone who wants to find out will find out. There is no real way of protecting source files or any other info from someone focused on finding out... I'm concerned about this too but not much you can really do...
