Pricing Section
Discussion in 'One Page Pro WordPress Theme' started by renarts, Jun 15, 2016.
  1. renarts
    renarts Member
    Hi there!
    I need help on the pricing section. What if I only have one product? Is there a way to remove the other two and then have the single pricing table centered?
    Your help is much appreciated. Thanks in advance!
  3. renarts
    renarts Member
    Thanks a lot!
    This worked.
    You're welcome..
