Gourav, I'd appreciate some direction on how to adjust the code so that the primary and secondary widget areas sit side by side instead of on top of each other. Many thanks.
Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. If this isn't something you're able to do then you would need to hire a developer for this.
