Primary and Secondary Widgets ended up in Footer section
Discussion in 'Cloriato WordPress Theme' started by midoricraft, Jan 15, 2013.
  1. midoricraft
    midoricraft Member
    I installed WOOCommerce plugin for my online shop. But the primary and secondary widgets ended up in Footer section. This only happened in my SHOP page. I guessed the problem could be due to WOOCommerce plugin, but checking how do I remove these widgets? If there is no solution, would you kindly recommend what other eCommerce plugins would work well with Cloriato theme please?
  2. Harmeet
    Harmeet Support Staff
    Sometimes plugin creates problem with the theme, so it would be better to try any other plugin which can perform the same task.
    We would recommend you that you can go to "wordpress.org" and find the plugin there. you will get many option there.
