Hello! Is there a way to move either the Primary or the Secondary Widget over to the left side of my website? My site is damageawayusa.com/wordpress Thanks! Tim
Hello, Go to the Appearance > Widgets panel in your dashboard and remove all the widgets from Primary or the Secondary Widget area (of which you want to remove from sidebar) and then drag & drop Text Widget either in the Primary or the Secondary Widget area and clear all the text from text widget . This will remove the section that you want from the sidebar.
Thank you for your response, but I was looking to be able to move one of the widgets to the left side, not just get rid of the widget. Is that possible to have one of them on the left side of my pages? Thanks! Tim
Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. Thanks & Regards Gourav Shrivastava
