Print of homepage cuts off right column
Discussion in 'Infoway WordPress Theme' started by superevent, Jul 3, 2014.
  1. superevent
    superevent Guest
    Hi there,
    when printing homepage the right column is cut off.
    I can see that this also happens on the infoway preview examples you have on your website.
    It work ok with print on other themes like for instance Geocraft.
    Can you please inform me how to solve this printing issue ?
    My website is www.SuperLEJ.dk
    Thanks!
    Print site with the settings shown in the image attached.
    It will work.
    Nitesh Raghuwanshi
  3. superevent
    superevent Guest
    Hi there - I know it will wotk with "landscape" but honestly this is not a solution that will work as no visitors will print in landscape.
    Do you have a solution for how everything on the site can be printed using standard print settings = portrait?
    This works on you other site designs i.e. Geocraft etc.
    Best regards
    Palle
  4. nfrohm
    nfrohm New Member
    Having the same issue, and it doesn't seem to matter what page size I select. I see a lot of others asking thsi question, but not really getting a fair answer. Can you please help us?
  5. nfrohm
    nfrohm New Member
    Here is an example of how it is cutting everything off even when printing at reduced size. [​IMG]
  6. nfrohm
    nfrohm New Member
    Any ideas?
  7. sameerwalkar
    sameerwalkar Guest
    We certainly understand your concern.
    But in this case browser automatically crop and adjust page size to fit the portrait form or the other desired paper size.
    Hope you understand our concern.
    Let me know for further doubts.
  8. nfrohm
    nfrohm New Member
    Unfortunately, that doesn't help and I don't understand. Every other website that is the same width prints fine.
