Problem Log In to My dashboard
Discussion in 'GeoCraft WordPress Theme' started by fakhr1970, Dec 7, 2012.
  1. fakhr1970
    fakhr1970 New Member
    When I'm trying login into my wp dashboard I redirected to the main directory listing site.
    Any suggestion here?
  2. Krish
    Krish Support Staff
    India
    Didn't you get a custom login page on your site?
  3. emarrufo
    emarrufo New Member
    fakhr1970, I had the same problem after I added a comment on the site to one of the dummy listings. Use the login info under the search box on the left and you will go to your dashboard as usual. I have deleted the comment to see if it goes back to working properly and it seems like it did. Hope this help you, EMarrufo
