Problem while upgrade theme
Discussion in 'ReThink WordPress Theme' started by eka, Oct 3, 2013.
  1. eka
    eka New Member
    I did to upgrade my theme from ver. 1 to ver. 2.0.5
    but it show problem on menu
    please see the pict : http://prntscr.com/1uzom6
    please advice
    thanks
    This issue may be because of plugin (if installed). So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s).
    If this problem still exist then please share your website link so that we will check your issue.
  3. eka
    eka New Member
    Thanks for your advice.
    this problem is solved now.
    After upgrade the theme file, I must to open theme option, and click save
    only that..
    Solved :)
