Problem with a Callpress Calendar plugin using Colorway PRO theme
Discussion in 'ColorWay WordPress Theme' started by stenvide, Feb 20, 2013.
  1. stenvide
    stenvide New Member
    I can´t find out what the problem is with plugin CalPress Calendar 1.5.0 by Aspire2 (on Wordpress)
    When I had the free version of Colorway it all worked out fine to write and publish events, but since upgrading to PRO-version I can´t write publish events any longer. Well, I can write them but the still ar unvisable both in "All Events" and on the calendarpage on my homepage.
    I have tried to unistall the CalPress Calendar and install it again, but there´s the same problem. It just doesn´t work
    I have the latest version of Wordpress 3.5.1 on my site/homepage and the Colorway PRO (paid version)
    Have some of you any idea what may be the problem?
    Eva
  2. stenvide
    stenvide New Member
    I have to tell You all that all my problems have been solved by the excellent team on CalPress Support Team and Don Kassing http://www.calpresspro.com
    Though I just have the free version of the CalPress Event Calendar their support was excellent and the helped my all the way to make the plugin work with Inkthemes Colorway PRO!
    If You consider a nice calendar, take a look CalPress Calendar free or PRO. If there some problems they will help You until it works.
    / Eva
