Problem With Comments "Off" Automatically...
Discussion in 'Harrington- A WordPress Business Theme.' started by helpful4you, Jun 15, 2014.
  1. helpful4you
    helpful4you Member
    I am not sure what the problem is.
    When I am posting a post wordpress always changes the status to "Comments Off".
    This is very weird.
    I made a video to show it.
    See: http://lottiworld.com/problem
    (this link will stop working after the
    problem is solved as I will delete that video clip then)
    First I thought it has to do with the Disqus Comment Plugin, but even if I turn
    off all plugins I get this behavior.
    Any ideas what causes this?
    Theme don't have such problem.
    Please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s).
    It will work. If not then Please provide the following information listed below.
    Thread Link: http://www.inkthemes.com/community/threads/problem-with-comments-off-automatically.12436/
    Your Website URL:
    WordPress Username:
    WordPress Password:
    I will check and resolve your issue.
    Nitesh Raghuwanshi
  3. helpful4you
    helpful4you Member
    Thanks, you were right. I did just follow your procedure and found the offending plugin that causes this problem. Thanks!
