problem with Google Api
Discussion in 'GeoCraft WordPress Theme' started by shopberater, Oct 12, 2016.
  1. shopberater
    shopberater New Member
    hi Guys,
    I have a problem with Google Api. I get the following message:
    "An error has occurred.
    Google Maps was not loaded correctly on this page. For technical details, please refer to the JavaScript console
    I have now tried everything, but can not continue.
    Thanks for your help
    Greetings from Vienna
    Thomas
  2. Naveen
    Hi Thomas,
    Thanks for contacting us,
    I would like to inform you that, google has recently updated its Map API and it will work only with a proper Map API key.
    We have already updated our theme with the required functionality, you can check the theme's changelog from here:
    https://www.inkthemes.com/community/threads/geocraft-theme-v-2-0-9-is-available.18853/
    You are requested to create a proper Javascript Map API key with your domain authentication from here:
    https://developers.google.com/maps/documentation/javascript/get-api-key
    and use it in the specified area under theme options of our updated version of the theme see: http://screenpresso.com/=jurTe
    Your map will start appearing and will work fine.
    You need to just update your theme to the latest version available in member's area.
    Please create the key and use it as mentioned above.
    Warm Regards!
    Naveen Kolhe
  3. shopberater
    Hello Naveen,
    Had done everything properly according to the instructions for Google Api.
    But nothing changes. Stay as before. ( See also Screenshot)
    I use the latest version of the GeoCraft Theme.
    One more note: the screenshot link does not work.
    What else can I try?
    Best regards from Vienna
    Thomas
  4. Naveen
    Alright..!
    Kindly, share your WordPress admin credentials at [email protected]
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    We will check and do the needful to your site.
    Warm Regards!
    Naveen Kolhe
  5. shopberater
    I found the mistake.
    1. This is because you can not specify any sub-pages for Multisite, and must be marked with "/" characters in Google Api as.
    2. After saving the api code, save and reload the dashboard.
    Then it worked synonymous with the takeover of the map.
  6. Naveen
    That seems to be helpful information..Thanks!
