Problem with Google maps widget on ClassiCraft theme
Discussion in 'General InkThemes Discussion and Feedback' started by dmsgroup, Sep 4, 2016.
  1. dmsgroup
    dmsgroup New Member
    On my website at http://lubbockjobsandemployment.com there is a part of the Classicraft theme that shows a Google map. It's not a plugin, but rather a part of the integral theme itself. However, it is not rendering properly, and this is what it is displaying on each ad:
    Warning: simplexml_load_file(http://maps.googleapis.com/maps/api/geocode/xml?address=&sensor=false): failed to open stream: HTTP request failed! HTTP/1.0 400 Bad Request in/home/dmsgroup2/public_html/wp-content/themes/classicrafttheme/library/map/single_map.phpon line 12
    Warning: simplexml_load_file(): I/O warning : failed to load external entity "http://maps.googleapis.com/maps/api/geocode/xml?address=&sensor=false" in/home/dmsgroup2/public_html/wp-content/themes/classicrafttheme/library/map/single_map.phpon line 12
    Is there tech support available for this question?
