PROBLEM WITH MAX MEGA MENU PLUG IN
Discussion in 'Quick Online Shop WordPress Theme' started by grandhiravi, Aug 20, 2017.
  1. grandhiravi
    grandhiravi New Member
    Dear Ink Themes Team,
    I have installed the Max Mega Menu Plugin in my WordPress. But when I am activating this plugin I am facing a problem, the slider in the theme is disappearing, and menu bar also going to high. I request you to help me in solving this problem
  2. akbar92
    I would like to inform you that, you are not supposed to use Max Mega Menu plugin with our theme as it requires some CSS and JS modification.
    If you still want to use this plugin with our theme, we can assist you in this regard but there would be some charges.
    Thanks & Regards,
    Akbar
  3. grandhiravi
    This is only for this particular theme, or the Max Mega Menu plugin won't work with all your thems,
  4. akbar92
    Yes, the Max Mega Menu plugin won't work properly with all our theme. It needs some CSS & JS manipulation.
    Hope you understand this.
    Akbar
  5. grandhiravi
    Fine, you are providing very good and excellent themes. Why don't you update the themes which are compatible with the max mega menu and other important plugins?
  6. akbar92
    We have concerned your suggestion.
    Hopefully, you will get it in the next update.
    Akbar
