Problem with page creation
Discussion in 'Local Business WordPress Theme' started by VipsK, Nov 26, 2012.
  1. VipsK
    VipsK Guest
    hi,
    I am having some issues I hope you can help me with.
    1. I am trying to add a new page, so I started by editing the sample page, but that one I can not change the page url, it keeps being stuck on my home page url. www.safetyforkids.org.uk
    So I thought I would start a brand new page, which went fine - with the new page I got my safetyforkids.org.uk/childrens-safety-kits url which I wanted.
    However if I try to remove the sample page the template disappeared so I thought I would try to leave the header blank but then I get a shaded block in my tab section, so I then wrote 'About' to see if that would change the permalink - but no it did not. So how do I remove this sample page (now called About) without disturbing the template??
    2. How do I edit the 'read more' url? As at present if I write in the
    "First Feature Description"
    area, it seems to go on and on and on, but I wish for it to have that 'read more' ability but can not find where I put/edit that url.....
    3. How do I get the footer widget to show the information you have at the bottom of the template, I also would like the map, the contact us and the other content....
    1.For your first issue
    Just go Appearance > Menus
    Create a custom menu and only add the pages you want to show to the public in the navigation bar.
    2.For your second issue.
    Go to
    Appearance > Theme Option > Homepage Feature Area > First Feature link
    and add your link address there.
    3.For your third issue
    You are talking about footer widget area, Go to the
    Appearance > Widgets
    Drag text widgets and drop them in the first, second and third widget area and create your own widget
    and for adding Google map
    http://screencast.com/t/ei3iAIgJrtqc
