Good day, There is a problem with pagination in Bizway theme. Please take a look: http://arborprof.ru/article (blog of category with articles). There is a bunch of all articles which is ugly. I need to display 10 articles per page and get any kind of pagination [1] [2] etc. Pagenavi plugin does not working. As concerning theme modifications, I've searched for common tricks, but due to theme structure I don't know where to add these modifications. http://sgwordpress.com/teaches/how-to-add-wordpress-pagination-without-a-plugin/ Since Biztheme was modified on my site, I be afraid to update it to its latest version. Could you, please, give me an advice which files should be updated manually to solve issue with pagination?
Hello praveen, I've examined settings and there are correct values in mentioned fields (set to 10). I suppose it's problem with theme code. perhaps it was modified. could you explain which files are needed to be updated, please? http://prntscr.com/6kbo7v
Hello gestapo! We have checked your website and find that you are using lite version of BizWay theme. Please switch to PRO version of BizWay theme which already have the pagination feature. OR, You can follow the link given below to add pagination manually in lite version of theme. http://www.wpbeginner.com/wp-themes/how-to-add-numeric-pagination-in-your-wordpress-theme/ Thanks, Praveen
Hello praveen, I've installed BizWay Pro version and activated it, but the problem is the same: theme is changed, but there are no limits with pagination. I've configured params to 10 in Settings > reading as you advised above. Also this hack took no effect with BizWay Lite version: http://www.wpbeginner.com/wp-themes/how-to-add-numeric-pagination-in-your-wordpress-theme/ Maybe I pasted the code in wrong line, don't know. Could I ask you to help me with pagination? I'll afford credentials ( admin / FTP access). Thanks.
Hello gestapo! Please send us your website wordpress login details at [email protected] along with thread link. Thanks, Praveen
Hello gestapo! We have checked your website and found a lots of customization in theme and uses of some shortcodes as well which affect and override the functionality of default pagination. So, I would like to recommend you to download and install a fresh copy of theme, insert the content and if any issue occurs,then please contact us for further assistance. Thanks, Praveen
