Problem with testimonial / Change to subpages
Discussion in 'RoadFighter WordPress Theme' started by cduartem, Oct 22, 2013.
  1. cduartem
    cduartem New Member
    Hi
    I hope you can help me with this:
    1. The testimonial block isn't showing on the homepage
    2. I need to add a grey vertical line on the default template to separate the contents and the widgets
    My website is www.kinesiologomovil.cl
    1. Go to the Appearance > Widget panel in your dashboard and remove all the widgets from the Home Page Sidebar Widget Area.
    This will display your testimonial block on the homepage.
    2. Paste the following code in your Custom CSS
    .page-content .content-bar {
    border-right: 1px solid grey;
    margin-right: 0px;
    padding-right: 30px;
    In place of "grey" you can put your color or color code.
  3. cduartem
    cduartem New Member
    Thanks!
