Problem with the Slider
Discussion in 'Cloriato WordPress Theme' started by netspezi, Jan 10, 2013.
  1. netspezi
    netspezi New Member
    Hello Guys
    in the Thema , there is a real problem with the slider. If you use 4 pictures with text, you can see at the beginning every 4 texts on the first image. That looks just does not look nice. Although it only takes seconds but the visitors of the website is not exactly happy about it. I talked with my hosting provider and says it is onThema.
    Can you fix it? or tell me what the provider must do?
    thank you
    michael
  2. dannyschrijvershof
    dannyschrijvershof New Member
    Hello ,
    I have the same problemens
    How can i fix it?
    Danny
  3. Gourav
    We are looking to your issue and reply you as soon as possible.
  4. netspezi
    netspezi New Member
    do you have more Informations ?
    thx
    Mike
  5. Piyush
  6. Piyush
  7. dannyschrijvershof
    Hello Piyush,
    Thank you very much.
    It's works great now!
