Problem with Theme Options with PhP 7.0
Discussion in 'Figero WordPress Theme' started by galesburgpl, Feb 22, 2018.
  1. galesburgpl
    galesburgpl Member
    When we updated our hosting to php 7.0, we had to manually change a few eregin the code to pregs to keep it compatible. Ever since updating the php and the affected code, we cannot access all of Theme Options in the WP dashboard. When reverting the php to 5.6 and changing the code back, it becomes immediately accessible again. But when updated, only the general settings menu shows. Any other menu (slider settings, footer, etc.) shows only a blank white screen to the right of the menu list.
    Any advice on how to fix this?
  2. akbar92
    Greeting from InkThemes,
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
  3. galesburgpl
    galesburgpl Member
    Thank you. I have emailed you the necessary information.
  4. akbar92
    I have already replied you in this regard on your email.
    Please check your e-mail and let me know.
    Akbar
  5. shineadmin
    shineadmin New Member
    Glasgow UK
    Hi having some problems with the figero theme used theme check plugin that tells me various problems are being incurred i made changes to file permissions to allow some features to be resolved but still having issues with changing the theme colour and using the theme templates ill email enquiries@ to allow you to resolve or offer me a solution - cheers
  6. akbar92
    Yes, please send the below-mentioned credential details at [email protected] along with the thread link.
    Akbar
