problem with try responsible menu and nextgen
Discussion in 'BlackBird WordPress Theme' started by knapik, May 10, 2014.
  1. knapik
    knapik New Member
    hello,
    i have two big problem:
    - in the responsible mode (with the mobile menu) the menu is not center on the screen, you must move on your right before see it...
    - the nextgen pro slider are not propely center on the page
    Before the update wordpress 3.9.1 is worked perfectly...
    What is the issue.
    You can have a look on http://revesdegosse.fr/ils-nous-soutiennent/marraine-parrain
    many thanks
    tony
    We have visited your website the problem is occurring due to any one of the plugin you are using, Deactivate all plugins one by one and checkout which plugin creating this problem.
    Gourav Shrivastava
  3. knapik
    knapik New Member
    hello,
    thanks for your return, you are right it's the wp-shop the problem.
    many thanks
    two another small question:
    - do you know an easy shop plugin fully compatible with blakbird
    - what is the diference between 2.0 and 2.1 version
