Problem with Website Description in Google
Discussion in 'GeoCraft WordPress Theme' started by senton, Feb 13, 2017.
  1. senton
    senton Member
    Hello
    I am not sure what the issue is but my website description is not showing
    up in Google.
    When performing a search for my site the following appears:
    'A description for this result is not available because of this site's robots.txt'
    I am not sure how to fix this and need assistance please.
  2. nitin
    nitin Guest
    To set your site description, just go to Dashboard-> Settings-> General-> Tagline and enter the required description for your site.
    This description will help google in indexing your site for SEO operations as well.
    Additionally, I want to let you know that the site descriptions and things such as parameters for the SEO take some time for populating and does not reflect instantly.
    Hope this helps...!
    Nitin
  3. senton
    senton Member
    No this actually does not help as I have always had the tagline filled in with a description.
    Can someone please take a look at this
    and find out whats happening?
  4. Naveen
    You can make use of some plugin like Yoast SEO to enhance your website SEO.
    Also, Google takes some time to display the changes of a website, so you must have patience for that.
    Warm Regards!
    Naveen Kolhe
