Problem with words wrapping around pictures properly
Discussion in 'Blackriders WordPress Theme' started by cholcombe, Oct 30, 2013.
  1. cholcombe
    cholcombe New Member
    I've tried the suggestions in the previous posts of
    /* wrap text around photos correctly */
    .page-content .content-bar img{
    float:center;
    and
    .content-bar img {
    float: center;
    margin-right: 20px;
    But I'm still having problems.
    http://dev.fixmypain.ca/canada/ - The text should be next to it. Currently, it only displays one line.
    http://dev.fixmypain.ca/about-us/doctors/ - the pictures should be centered in the column.
    Thanks for you help.
    Remove code you have posted above and paste this code in Custom CSS
    .ezcol.ezcol-one-half {
    text-align: center;
    .page-content .content-bar img {
    float: left!important;
    It will work.
  3. cholcombe
    Thank you for your reply. I deleted the code I had before, and replaced it with the code above. I'm still getting the same results. Is there anything else I can try?
  4. Nitesh
    Go to the
    Appearance > Theme options > Custom css and correct previous code as shown in the image.
