Problems: Slide Header wrong place, Turn Off Blog doesn't work probably.
Discussion in 'RoadFighter WordPress Theme' started by swmgmbh, Oct 21, 2013.
  1. swmgmbh
    swmgmbh New Member
    Dear Sir or Madame,
    the Theme RoadFighter isn’t working probably.
    The turn off switch for blog posts on the home-site doesn’t work right, there is still standing "Blogposts:" and the slide picture is under the logo and the menu.
    Please send me a working version.
    You can see the problems here: http://immoreal-consultants.com/
    Best Regards
    Fabian
    PS: An improvement advice - start working with language files so it’s easier to translate the theme in other languages.
    Please visit link given below. It is of demo site.
    Themes is designed according to the pc view with slider from the top of screen.
    http://inkthemes.com/wptheme/roadfighter-yoga/
    But if we go to your site. It contain header at the top and then slider (In pc view).
    So go to the Dashboard > Settings > Reading and set it to default.
    I hope it will resolve your problem.
  3. keara7
    keara7 New Member
    Hi my menu is above the slider with a grey bar. Not sure how I can correct this. I have just loaded the theme so havent changed any settings. Please advise. I have attached a screen shot to show you the grey bar.
  4. Piyush
