problems translating
Discussion in 'GeoCraft WordPress Theme' started by zweitbuch, Mar 19, 2014.
  1. zweitbuch
    zweitbuch Member
    hello!​
    I am facing some problems translating the theme, i already translated the Po and mo files, but still a lot of texts are in english.​
    I figured out that the texts change when i change them in library-textdomains, but is that the right way to do it??​
    Please do let me know in which text you are getting problem.
    Nitesh Raghuwanshi
  3. zweitbuch
    zweitbuch Member
    actually there are a couple of texts, where i face this problem, can i change the texts in library textdomains or does that harm the code?
  4. Gourav
    Yes, It is a correct file to change the text, you can change text from there. It does not harm any code.
    Gourav Shrivastava
