Hello, It is image size issue of header. You are using the smaller image for header because of that the menu messed up when you add the social logos. So, edit your header image and do increase its dimension with the help of photoshop or any image editing tool. This will solve your issue.
Sorry i should have been able to figure that out but on a different subject how do i remove the read more links in the image below
Hello, Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .feature_contentbox a.readmore { display: none; }
