Since I updated to new Theme version 2.0.7 I have some new problems: 1) In editor the Listing Tags and Listing Location Tags have disappeared, And I am not able to set new Tags ? 2) The section for uploading Listing Images has disappeared ? Please advise asap. PS: Since I purchased this Theme approx 2 months ago, there seems to be many ongoing issues and problems. I do hope you get this theme working correctly soon because it's costing my business time and money.
Hello Zoro, Greetings from InkThemes! Sorry for all your troubles... I have checked your issue and we would like to inform you that we didn't find such an issue at our end. So could you please share your dashboard credentials at [email protected] along with this thread link as well so that we can figure out the issue and able to resolve that? Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka, I have again re-installed the new 2.0.7 zip, and it looks like the issue is fixed. But, new problem: Every-time I update the Theme some of the settings are removed, and now I need again to re-set some of my original settings. Why can't the Theme Updates just be Automatic from dashboard like most other themes do? Thanks again for your great support.
Hello Zoro, I am really sorry for all the inconvenience.. But you have to update all the setting manually.. Hope you will understand, Thanks & Regards! Priyanka InkThemes.com
Ummm. It might be nice to publish new Child Theme instructions. BY using a Child Theme, edits to stylesheets or other files do not get overwritten when updating the Parent theme.
Hello Joshuasloan, I respect your thinking.. If it would be possible in future, I will sure let you know.. Hope you understand, Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka, So what you are saying is that every time I install a new updated version, I will need to go back a reset all my settings? Surely this can't be correct ? Please advise.
Hello Zoro, If you will reinstall the theme with the same way as mention in the given link http://www.inkthemes.com/community/threads/geocraft-theme-v-2-0-7-is-available.18853/, you will not lose any of your Theme Option setting. you will only lose your source code customization whatever you have done in the theme. Hope you will get my point, Thanks & Regards! Priyanka InkThemes.com
