Problems with checkout form in IE
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by chmchm, Mar 17, 2015.
  1. chmchm
    chmchm New Member
    Hello!
    my site is experiencing issues with the check out form in Internet Explorer. The form seems to be in behind something and the user can't fill out the form.
    Can you help?
    sparoom.com
    Thanks!
  2. chmchm
    chmchm New Member
    Upon further investigation, it seems to be the "select2-drop-mask" class somehow covering the screen. When I set it to display none, the problem is resolved. I just did it in the inspector, not fully aware of it's function in the theme.
