Hi, I continue to have problems with my editor. Now whenever I put in a return to create space between paragraphs, it doesn't save it. Any suggestions as to why and how I can fix it? Thank you, Kimberly
Hello, In text editor HTML tags will works fine. So for the space between the words you can use " " Code instead of spacebar in text editor. Or you can create space between the words by the spacebar in visual editor. This will also work fine.
