Problems with frontpage
Discussion in 'Gommero WordPress Theme' started by mwnow, Apr 29, 2014.
  1. mwnow
    mwnow Member
    last week our frontpage is broken. www.zartherb-aichach.de
    We haven´t updated sth, oder installed plugins...
    If you enter: www.zartherb-aichach.de
    there is only a blank page shown
    BackEnd works fine
    > so I have updatet wp on 3.9 but it still doesn´t work.
    I tried to activate the wp standart theme (twenty eleven) but its again only a blank page shown
    I have deactivated all plugins...same problem
    The child-sites work fine:
    www.zartherb-aichach.de/news
    What can I do?
    I´ve got ones this error (when I installed the theme new, and clicked on "theme preview"
    Parse error: syntax error, unexpected T_FUNCTION in /hp/av/aa/ui/www/thefivestars/wp36/wp-content/themes/mango/functions.php on line 73
    If you need I can give you the login files for wp backend via pn!
    Thanks!
  3. mwnow
    mwnow Member
    sure! I´ve actually sent you the mail!
    Thanks!
  4. Piyush
    The error given below is the memory allocation error of your website.
    Fatal error: Out of memory (allocated 79429632) (tried to allocate 35 bytes) in /homepages/7/d479810411/htdocs/clickandbuilds/WordPress/wp-includes/wp-db.php on line 1941
    Contact with your service provider and asked them to increase the memory allocated for your website.
  5. mwnow
    mwnow Member
    Thanks for your answer.
    I had called our provider and asked them about the memory limit > they told me it´s 60 Mbyte big > that should be enough, I would thougt?
    Or did you mean another size?
  6. Gourav
