Problems with "latest blog post" slider on homepage
Discussion in 'ColorWay WordPress Theme' started by rachelkatz45, Jan 20, 2016.
  1. rachelkatz45
    rachelkatz45 New Member
    Ever since the update my blog post slider on my homepage (bottom right) is disproportionate and not lining up. My website is http://thefullifebyrachel.com/ . How do I correct this? Thank you!
    Would you please reinstall the theme from the members area and check after that..
  3. rachelkatz45
    Hi Priyanka,
    Do I just install it the same way I did before?
    Download the ColorWay theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder colorway like colorway_new,
    Again, you would need to create a zip file of that renamed folder (say: colorway_new.zip),
    Then, activate your theme,
    Hope you will find it helpful..
