Problems with Thrive Visual Editor plugin
Discussion in 'ButterBelly WordPress Theme' started by GregJD74, Aug 4, 2014.
  1. GregJD74
    GregJD74 New Member
    The plugin no longer function properly, it will open the editor but none of the functions are present.
    Old pages that were built with the plugin do not function properly either. Things like links on those pages are dead, though the formatting is available.
    Thank you for looking into this.
    Our themes are compatible with almost all the plugin available in WordPress.org but there are thousands of plugin available on WordPress.org and some are regularly updating and some are not updated from many years therefore it is not possible for us to check every plugin with our theme, So you can search any alternative of that plugin.
    Or
    You can also contact to plugin related support forum. They will help you.
    Gourav Shrivastava
