Problems with Wordpress SEO Yoast on this theme
Discussion in 'Blackriders WordPress Theme' started by sigan29, Jul 1, 2014.
  1. sigan29
    sigan29 New Member
    I have been using the plugin wordpress seo yoast with other inkthemes themes but recently, I encountered a problem with this plugin on this theme only. Only the header of the plugin can be seen on the pages and it can't be expanded. The plugin works fine on posts. Please help.
    I will wait for your response.
    Thanks.
    Please do let me know your website link.
    Nitesh Raghuwanshi
  3. sigan29
    sigan29 New Member
  4. sigan29
    sigan29 New Member
    Hi Guys, any news on this issue?
  5. Nitesh
  6. sigan29
    sigan29 New Member
    Nitesh, I think you have misunderstood my problem. I don't have double titles. The Yoast information box on PAGES does not show any detail, only the header. It shows the detail on POSTS but not on PAGES. I have attached a screenshot showing what I mean.
    Normally there is an editable box under the header which allows you to set keyword. meta titles etc but on this theme/site it does not appear on PAGES, so I can't optimise the page for seo.
    Thanks, Pat
  7. Gourav
    Wordpress SEO Yoast plugin is compatible with our theme but in your case it is not working, I think other plugin jquery is conflicting with the Wordpress SEO Yoast plugin jquery, So we suggest you to deactivate all other plugin(if installed) one by one and check which plugin is conflicting with the Yoast plugin.
    Gourav Shrivastava
  8. sigan29
    sigan29 New Member
    Thank you for your help, we did as you suggested and it was an issue with a plug in called media link. We have now deactivated that plug in and the site is back to normal.
