Hi, I have a problem with the product category pages on my website. They look plain and seems like it didn't display correctly. I've attached here a screenshot. Please help on how I can fix these pages.
Hello, Please download theme (v 1.1.4) again from your members area and upload it. It will resolve this issue. Thanks & Regards Nitesh Raghuwanshi
Thanks for the response. I've tried doing it and it worked for those pages, however, some of the changes I've made on the site aren't visible with the new version of the theme.
Hello, Your theme option content and css code in the Custom CSS section will remain intact while Theme update, but if you have done any changes in .php files (like header.php, sidebar.php ,footer.php..etc.) of theme then you will loss your changes while Theme update.
Okay, so is there anyway my problem can be fixed without updating the theme? I've had a lot of important changes I've created on the site and losing them won't make sense.
Hello, It is not possible to fix the problem without the theme version update, But for you can add your customized .php files in the child theme directory. Child theme will work for files which are in parent directory. Please follow the link given below http://www.inkthemes.com/httpwww-in...rdpress-a-way-to-save-themes-modification/02/
Hi Gourav, I just did this, so basically, I'll create a child theme with the new version as the parent theme, right? Then I'll just add the customized .php files in the same folder, is that correct?
Hello, Yes just create child theme and add your customized files in it. Check link for more info. http://www.inkthemes.com/httpwww-inkthemes-comhow-to-create-a-child-theme-in-wordpress-a-way-to-save-themes-modification/02/ Thanks & Regards Nitesh Raghuwanshi
