Product Color Options
Discussion in 'Dzonia WordPress Theme' started by katmoline, Mar 19, 2014.
  1. katmoline
    katmoline New Member
    I'm not sure if this is the best place to ask this but I thought someone here might be able to help. I've created the multiple files with the same image of our product in the various color options available. I'd like to figure out how to have the image change to the color when the customer hovers over the color title. So the image is at top and appears to be static but when the customer hovers over "white" for instance, it automatically shows the white product image.
    Any help is appreciated!!
    Thanks!
    You are asking for non-existing feature of the theme.
    So there isn't a way to do that with our theme unless you custom code something up. Sorry.
  3. katmoline
    Ok, thanks. Do you know where I might be able to get such custom code? For purchase perhaps?
  4. Piyush
  5. katmoline
    Do you happen to have any good references for freelancers? Or a place to find reliable freelancers? Thanks!
