Product Quantity Cart Button Situation....Not Show up on Samsung Tab.....
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by effyeweb, Apr 3, 2015.
  1. effyeweb
    effyeweb Member
  2. sameerwalkar
    sameerwalkar Guest
    Due to some customization in woo commerce plugin made recently by their developer team, the feature of +/- button in product page is now no longer available. That's why these buttons are not displaying on the product page.
    But don't worry about that, our developer team has also customized our theme and provide the feature of adding and subtracting product items in a different form.
    See attachment
    So now you can +/- your cart as shown in above image.
    Still you can provide us you edited screen shots of your issue we will look after it
    Sameer
  3. effyeweb
    effyeweb Member
    1234.jpg yes..... the +/- button in window is allright......... but not function in android system.....sumsung..... you try.....
  4. sameerwalkar
    sameerwalkar Guest
    I have checked at our end its working fine you can check the below image provided:
    Try to clear cache memory of your browser by going into browser settings of your Samsung Tab. It should work and will solve your issue.
    Sameer
  5. effyeweb
    effyeweb Member
    i just clear the cache and everything......but still same..... i do not know why
    Google Browser
    Samsung Browser
  6. sameerwalkar
    sameerwalkar Guest
    I did another round of testing on the quantity up down arrows that you are facing. As noted its not a CSS issue, it might be a default functionality (i.e. one can directly add or edit the quantity by inserting number of quantities) that they had provided on mobile devices. Still I will suggest you to put your query on woo commerce support forum, and get their advice regarding the same. Based on their inputs, If there is any changes we will try our best to solve it.
  7. effyeweb
    effyeweb Member
    is it this is default of woo commerce , for client to enter the quantity of product by key in no....... that is not user friendly...... can you help...... it influence salejunction performance on mobile device......
  8. sameerwalkar
    sameerwalkar Guest
    Hello Effyeweb,
    We appreciate your concern. Though it's a woo commerce functionality. But still I have noted down your query as a suggestion and will put forward to our Technical team.
    We will try to find out some way to fix this issue if possible and then get back to you with some effective solution.
    Thanks for being patient and cooperating with us.
