Products : Tumbnail to expanded View Distorted
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by quinja2, Oct 1, 2013.
  1. quinja2
    quinja2 New Member
    When uploading products using WooCommerce, the thumbnails look great. They look great on mobile too. However, when selected the thumbnail is expanded to an irregular size image that distorts the picture.
    Is there a reccomended size image that should be used to prevent this from happening. Or is there a way to keep the same size image on both pages?
    www.revegirls.com
    Use landscape images for your product, It will look fine.
  3. quinja2
    quinja2 New Member
    That will not work if your pictures that are provided are not all in Landscape. Is there a size that can be used or a way to remove the expansion of image all together?
  4. quinja2
    quinja2 New Member
