Publicize by Jetpack
Discussion in 'Local Business WordPress Theme' started by matthewford, Oct 4, 2013.
  1. matthewford
    matthewford Member
    I have 3 image widgets in the primary widget area on my site. I am using Publicize by Jetpack to automatically add my posts to Facebook and Twitter.
    The problem I am having is that when I do a new post, add an image to the post and then publish it the wrong image is displaying in Facebook. Facebook always chooses the first image in the primary widget area instead of the one I added to the post and also set as the featured image.
    If I disabled the image widgets by using the visibility option the plugin then chooses an image widget from the fo0ter widget area.
    I have another site with this theme with no image widgets and the posts work perfectly.
    Have you come across this issue before?
    Matthew
  2. matthewford
    matthewford Member
    Don't worry I have fixed it. Basically the images have to be 200 x 200 and then they work with the plug in.
