I work with Figero Pro 2.1 and just upgraded Wordpress to 3.8.12.1 Now I notice my pulldown menu is not working anymore. It just shows the level1-items, but not the sub-items. In other words: nothing happens on mouse-over... How can I solve this??
Hello, We have visited your website the problem is occurring due to any one of the plugin you are using, Deactivate all plugins one by one and checkout which plugin creating this problem. This will solve your issue.
Thanks for your fast respons. I did as you asked and de-activated all plugins one by one... The most important as last... Guess what... The last one is causing the problem - wp e-commerce HOWEVER: as you can imagine this is an important plugin for me. I will contact getshopped. But if you might have any alternative suggestion how to solve this I would highly appreciate! Kind regards, Hans
Meanwhile if found this: "Your theme loads an outdated version of jQuery. Remove this part, make sure the WordPress jQuery is used always. The WP E-Commerce plugin and all other plugins rely on an up-to-date jQuery." at http://wordpress.stackexchange.com/...gin-is-breaking-drop-down-menus-functionality I am not a programmer, but could this be relevant?
Yep.. it seems the above has been causing the problem. I now installed the 'jquerie updater plugin' and the menu's are working fine now. I am not sure, but I think the old jquerie came from Figero; you might look into that. Thanks! Hans
