Purchase confirmation emails not sending
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by raaj95, Dec 11, 2015.
  1. raaj95
    raaj95 Member
    No email recived when purchase is done ??? Purchase confirmation emails not sending
    website name - http://tradedp.com/
    We will check it at our level through your provided credentials earlier and will let you know.
  3. raaj95
    raaj95 Member
    I am waiting ????? Please check this ASAP
    Our developers are busy in some other implementation right now.
    So I will try my best to pull theme over your issue ASAP and will let you know the same.
  5. raaj95
    raaj95 Member
    Hello have you done ???
  6. priya
    You are suggested to try this for once and check after that
    Go to the Woocommerce options emails (Woocommerce=>Setting=>Email) and change the "Email Sender Options" to "wordpress@yourdomain.com".
  7. davidd2012
    davidd2012 New Member
    how did this turn out for you? i would like to know for my own sales. thanks
  8. priya
    To get this firstly you need to install "woocommerce" plugin in your dashboard and after that, you will get "Email Sender Options" option under woocommerce plugin.
    Hope you will get it helpful..
