Putting image in top right corner of web page on far side of Menu
Discussion in 'Regal WordPress Theme' started by webedge, Jul 13, 2016.
  1. webedge
    webedge Member
    In reading the post, https://www.inkthemes.com/community/threads/customization.8237/#post-35894 we can see how to place an image in the right corner under the menu in the header.
    What we would rather like to do is to place our image next to the menu on the far right side. So the menu would need to be moved to the left.
    How can this be done?
    Your help is greatly appreciated.
    -Jim
  2. nitin
    nitin Guest
    Hi Jim,
    You need to add the code given below :-
    <div class="cstm">
            <img src="URL of the image" />
        </div>
    To add the code, just follow the screenshot given below:-
    After adding the URL of your image, just let me know, I will provide you the required custom CSS code which will do the work for you.
    Hope this helps...!
    Nitin
  3. webedge
    webedge Member
    Nitin,
    Sorry that this response is so late...
    We have added the code that was provided to the "header.php" file. What is the next step we should follow?
    -Jim
    Hi, Jim..
