QTranslate and Colorway PRO
Discussion in 'ColorWay WordPress Theme' started by athsak, Mar 3, 2013.
  1. athsak
    athsak New Member
    Hi guys, awesome theme, I'm actually having issues I want to add one or two widgets (Search and Qtranslate) on the top right Corner so it can be visible to my visitors. Can you give me some suggestions do i need to paste something to the custom css?
    Cheers keep up the good work!
    Theme contain widget area at the bottom of front page, That is footer widget area. You can only add widgets there. It is not possible to add any widget on the top right corner.
