QTranslate not working with theme
Discussion in 'BlackBird WordPress Theme' started by rachelmazza, Apr 17, 2014.
  1. rachelmazza
    rachelmazza New Member
    It seems that QTranslate is not working with the current version of the theme.
    When I try to edit a page, I get the following message:
    "The qTranslate Editor has disabled itself because it hasn't been tested with your Wordpress version yet. This is done to prevent Wordpress from malfunctioning. You can reenable it by clicking here (may cause data loss! Use at own risk!). To remove this message permanently, please update qTranslate to the corresponding version."
    There is no current corresponding version, so I re-enable the plugin, but then cannot click on the editor for other languages.
    I am trying to add in photos to my Chinese pages at www.bwi.com.au , but cannot click on the Chinese text editor to add in the html.
    Any ideas on how I can add photos into my pages?
  3. rachelmazza
    Thank you.
    Using the information you provided, I'm trying to change
    define('QT_SUPPORTED_WP_VERSION', '3.8.1');
    to
    define('QT_SUPPORTED_WP_VERSION', '3.8.2');
    But can't find it in the WP theme editor. The article warns NOT to do this through FTP but to use the editor.
    Do you know where I can find this?
  4. rachelmazza
    Found it!!
    Thank you so much.
    You guys always fix everything..
