Hi there, me again. I installed qTranslate. Writing blog-posts works fine, but translating the HOME page does not work with the procedure described here for Colorway theme: "http://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin/01/" Any ideas how to translate my HOME page (incl. feature area)? Please note, that I am not using qTranslate as widget; I put a php coding into header.php. Thanks, Stephan
Hello, The whole process of translating the theme is given in the above given qTranslate blog link. Could you please share the link of your website and also specify the text on home page that you want to translate. Or You can also try Google Translator plugin for this issue. Download it from the link given below and install it from the Plugins panel (Plugins ->Add New ->Upload) in your Dashboard. http://wordpress.org/plugins/google-language-translator/screenshots/ Also check link for reference, I hope it will helps you http://www.inkthemes.com/make-multi-language-website-by-using-google-language-translator-plugin/08/ I hope this will help you.
