Hi, It seems that when I add new custom css to the box, only the top one works. Is this normal? Can I only use the custom css box once, or should it work if just paste the new codes underneath? Thanks Paul.
Hello paul, There is no limitation for custom css. You can add css code as much as you want. This problem is occurring because you have missed '}' curly bracket in your previous code. Check complete code again. It will resolve your problem. If not then please do let me know your website link.
