Questions about fonts etc.
Discussion in 'Harrington- A WordPress Business Theme.' started by niallg, Oct 2, 2014.
  1. niallg
    niallg Member
    I love your themes, I will probably become a nuisance with all my questions :
    1. How do I change the Colour of Theme Style sheet to a particular shade of red ?
    2. How do I edit text on slider ie the floating text and the heading etc.?
    3. How do I change font on whole theme ?
    4. Change font ,colour and size in : Home Page Feature section, Home page main and sub heading, and slider settings, Client testimonials section?
    5. Is it possible to put a video in slider section ?
    6. when I place images in the page area , the size increases to maximum bigger that the original size ? In particular in concert notes pages ?
    the URL of my site is : www.northsydneysymphony.com/blog/
    Thanking you for all your assistance with the slice theme
    Regards
    Niall
  2. Krish
    Krish Support Staff
    India
    Hello Niallg,
    Thanks for liking our themes.
    2. To edit slider heading text, follow the attached image slider-heading.png
    3. To change font on whole theme is, there is no option added for doing this. If you are familiar with stylesheet, I just give you the hint, where you can make your changes. Just see the attached image fonts.png
    4. * For feature section, use following code in custom css option on theme options:
    .feature_inner_box h6 a,
    .feature_inner_box p {
        color: your color value;
        font-size: your size value;
    * For home page main heading:
    .home_container .page_info h1 {
    color:your color value (eg:#000000);
    font-size: your size value (eg:12px);
    * For home page sub heading:
    .home_container .page_info p {
    * For slider title:
    .sy-caption-wrap .sy-caption h1{
    * For testimonial section
    .bx-wrapper .bx-viewport ul li p {
    5. Yes it is possible to put video on slider section.
    6. This is theme bug, I will notice this to fix on current theme and provide you on members area.
  3. niallg
    niallg Member
    Re- changing theme colour I want to change from the red that is in the dropdown menu (#EA3131) on theme style sheet to #C4272E (RED)which is a different shade.
  4. niallg
    niallg Member
  5. Pramod
    Pramod Guest
    Use this code for image.
    .fullwidth img {
    max-width: 100%;
    height: auto;
    For menu color
    Goto
    Appearance->theme editor-> style.css
    Find all CSS start with { #menu } and in this code find the color you want to replace and change it. after replacing all color code update file.
    Pramod
  6. niallg
    niallg Member
    Hi Pramod,
    re- the images, pasted the code in and it is still the same. I notice in the threads that other people have the same problem.
    Please fix as I need to have this site running soon.
    Regards
    Niall
  7. Yogesh
    Yogesh Guest
    .fullwidth img {
    width: auto;
    It will resolve your issue.
    Yogesh Bhade
