Re-activate Custom Menu
Discussion in 'Andrina WordPress Theme' started by eburrowes, Aug 6, 2013.
  1. eburrowes
    eburrowes New Member
    For some reason, the main navigation menu on the website is no longer being controlled through the custom menu feature. For example, if I add a page to the navigation or re-arrange pages using the custom menu feature, the navigation stays the same. It doesn't change. However, if I go to "Pages" and add a page there or re-arrange the pages there, then those changes are reflected on the website. It seems that a bit of code might have gotten removed or stopped working for some reason. Is there a code snippet that I can pop back into the theme files to re-activate the use of the custom menu feature? Thanks so much!
    Go to the Custom Menu panel (Appearance > Menu) in your dashboard and
    check whether you are selected the same custom menu from Main Menu combo box of Theme Locations section, and on which you re-arrange the pages.
    If not then make them same.
    See the image for reference.
    If not, then send us your dashboard details, we will check your issue.
    Thread Link: http://www.inkthemes.com/community/threads/re-activate-custom-menu.6587/
    Your Website URL:
    WordPress Username:
    WordPress Password:
  3. eburrowes
    Thank you so much! That was such a quick fix. I appreciate it your help!
