After the google update of the re-captha system, it is no longer displayed correctly on the user registration page. How to solve this problem?
Hello, Greetings from InkThemes, It seems like you are using the older version of the theme and this issue has fixed in the latest version of the theme. So, you are requested to update the theme to the latest version. To update the theme, First, visit your members area: https://www.inkthemes.com/members/member and download the latest version of the theme. Next, extract the zip file of the theme and rename that folder like theme_name to theme_name_new, Again, you would need to create a zip file of that renamed folder (say: theme_name_new.zip), Now, upload the theme to your WordPress from Dashboard->Appearance->Themes->Add New, Then, activate your theme, This way you can install and activate the latest version in your site, keeping the copy of your older version on your WordPress Hope you find it helpful, Do let me know if you need further assistance. I will be glad to assist you. Regards, Akbar InkThemes.com
